    Web Progress Bar - stuck at 100%? (custom slicer)
    Duet Web Control
    • TLAS
      TLAS last edited by
      I'm getting some odd behavior in my prints - they start at 100% complete and don't give any time estimates. I didn't realize how much I appreciated the time estimate feature until now.
      A bit of background here - I'm building a custom web slicing interface and am using a modified version of Slic3r. I fully expect that there could be some comment code or something similar I might be missing from the gcode files that enables the progress calculation. Any pointers as to what gcode lines I may be missing?
      Additional details:
      • WebUI says "Processing *.gcode, 100% Complete
      • Right hand says Layer 0 of 191(even when past the first layer)
      • Job duration and last layer time function correctly, current layer time does not.
      Firmware Name:
      RepRapFirmware for Duet 2 WiFi/Ethernet
      Firmware Electronics:
      Duet Ethernet 1.02 or later
      Firmware Version:
      2.0(RTOS) (2018-06-05b3)
      Web Interface Version:
      1.22.6
      TLAS Phaedrux 2 Replies Last reply Reply Quote 0
      • TLAS
        TLAS @TLAS last edited by
        @TLAS
        Another detail,
        When I printed the file again after it finished, the time estimates all worked... finding this really weird...
          Phaedrux Moderator @TLAS last edited by
          @TLAS said in Web Progress Bar - stuck at 100%? (custom slicer):
          Firmware Version:
          1.22.6
          These are quite out of date.
          Can you post a sample gcode?
          TLAS 1 Reply Last reply Reply Quote 0
          • TLAS
            TLAS @Phaedrux last edited by
            @Phaedrux
            Just actually switched over to a new Ethernet board yesterday. I was having the same problems with an older WiFi with everything up to date.
            Will post an example after I confirm the same behavior after updating.
