Duet 3 with Workbee.
  • Hello
    I am building a Workbee CNC Maschine and I am upgrading the controller from NOVUM to duet 3 with RPi. I am running the Duet3 with firmware 3.0 and dsf 1.2.4. attached are config G. file(config-5.g ) I am using.
    Homing is working but when I start a job I got after the homing the error: Error: G0/G1: target position outside machine limits.
    I installed the DWC from ooznest and it showing me under Maschine position "n/a"
    any idea why?
    thank you :-).
  • Does anyone have this issue before? I Tried everything but no chance!
  • Moderator
    I'm not sure what oozenest recommends for Duet3, (if anything), but you could try updating to 3.01-RC10 along with the associated other updates for the DWC and Pi.
    I don't know what you have in your homing files that could be generating the machine limits file.
    Your config.g also calls another config file that I can't see.
  • Hello Phaedrux,
    Thank you for your answer. could you please tell me how I can update from Firmware 3.0 to 3,01 RC10 using my Rpi?
    regarding the other config call, it is empty.
    Thank you in advance.
  • Moderator
    Since it is a release candidate, you would need to add the unstable repository to your pi using these steps
    https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation
    If you're not comfortable with that, you can wait until 3.01 is finalized which shouldn't be too long now.
