    Duet2CombinedIAP.bin assets file
    Firmware installation
    • danzaywer
      danzaywer last edited by
      Hi
      what is Duet2CombinedIAP.bin in 3.01-rc10 assets?
      I have to install it together with Duet2CombinedFirmware.bin?
      in what order?
        You probably are missing it from the 3.0 release. Update to that one first. The iap file just needs to be present you don’t flash it directly.
        • arhi
          arhi last edited by
          rc10 comes with it too so you don't need the one from 3.0
          Normally you upload that one first and then the Duet2CombinedFirmware.bin and the dwc will ask if you want to flash it. But for some reason I cannot upload the IAP file ?!?! DWC fails somehow, so I rename IAP file to xxx.xxx upload it (it uploads normally that way) then use DWC to rename it (right click/rename) in to original name directly on the duet, then upload Duet2CombinedFirmware.bin dwc will ask if you wanna flash, you click yes and voila you are upgraded
