    Warning if loaded filament does not match job material
    1
    119
    • jckrayundefined
      jckray
      I've just started looking into RRF3. With the new gcode meta-commands, it seems like I should be able to insert code from in the start code of a print job that would check to see if the loaded filament matched the filament the job was sliced for.
      The idea would be to have a line in the print job start gcode that is something like
      if filament !="*have Cura insert filament name*"
            M291 P"The loaded material does not match the material required for this job. Press OK to continue printing anyway" R"Incorrect Material Loaded" S3
      I didn't see anywhere in the documentation a way to call/compare the loaded filament. I thought that might be in the object model, but I didn't see anything there.
      Is this not yet implemented in RRF3? Is there another way to do this?
      John
      Founder of Hydra Research LLC, developers of the open-source 3D printers and providers of 3D printing services.
      https://www.hydraresearch3d.com/
