    Conditional Output status or Tool deselect script?
    Gcode meta commands
    185
    • mwwhited
      mwwhited last edited by mwwhited
      Re: Conditional Gcode and GPIO State
      Re: Tool deselect macro?
      Is it possible to write a conditional query to check that value currently sent to an output? I used M409 and can't find output or gpio status.
      On my duet3 I added a relay control board using io6.out, io7.out and io8.out. I want to be able to write code in the daemon.g that can compare the selected tool to these output states.
      Better still is there a gcode file that is execute when tool is deselected "T-1"? I'd prefer to not litter all of the tfreeX.g files with code to deenergize the relays.
      I saw another topic where someone suggested creating a fake tool "T99" and having that do the unload then set to -1. I'd prefer to not handle it this way.
      • OwenD
        OwenD last edited by
        I don't think you can poll the state of outputs yet.
        I think the object model only has inputs at this point.
        That said it's probably a waste of cycle time to continually poll them in daemon.g
        You could create a single macro to do that and execute it from each of the tprX.g or tfreeX.g file(s).
          dc42 administrators @OwenD last edited by
          @OwenD said in Conditional Output status or Tool deselect script?:
          You can read outputs in 3.01-RC10. Outputs are in array 'state.gpOut'.
          @mwwhited said in Conditional Output status or Tool deselect script?:
          • You could write a macro to do what you need, and call that macro in every tfree file
          • The next 3.01RC will have an additional variable state.nextTool that will be available for use in tfree and tpre files. Is that helpful?
          OwenD mwwhited 2 Replies Last reply Reply Quote 0
          • Danal
            Danal last edited by Danal
            A balance point available today would be to put M98 P"/macros/checkRelays.g" in every tfree. That, at least, allows maintaining the code for the relays in one place.
            • OwenD
              OwenD @dc42 last edited by
              @dc42 said in Conditional Output status or Tool deselect script?:
              Awesome.
              I missed that in the change-log ( I really do RTFM - promise !😀 )
              So it appears that you read the pwm property regardless of whether it's used as "standard" I/O?
              echo state.gpOut[5].pwm
                dc42 administrators @OwenD last edited by dc42
                Yes. You will get a value between 0.0 and 1.0. This is a recent addition, so please check that it works properly for you.
                If the port is being used to drive a servo, then if you are using the default servo refresh frequency of 50Hz then the servo pulse width should be (pwm * 20000) microseconds.
                • mwwhited
                  mwwhited @dc42 last edited by
                  I know I could do this as I stated above but it has two issues. 1) It can cause an unneeded transition (could be solved by your state.nextTool.) But more importantly 2) it causes code duplication and as a software guy this drives me crazy. (this could be solved with a generic tfree.g that all tools could share.)
                  As for the state.gpOut[X].pwm ... that will work. (I swear I looked but it must have been before I updated to RC10, I think I only saw gpio when I did M490 K"state") I still think having more events would be better but I can make my own by checking the status of tool changes.
                  @dc42, is there a generic spot that I can store state or am I still waiting on variables.
                  I already have a polling loop in daemon.g every few seconds anyway to monitor the temperature and fan status in my power supply.
                  • mwwhited
                    works great...
                    daemon.g
                    M98 P"0:/macros/Special Scripts/Check Relays"
                    if state.currentTool = -1
                    	if state.gpOut[0].pwm > 0 || state.gpOut[1].pwm > 0 || state.gpOut[2].pwm > 0
                    		M98 P"0:/macros/Special Scripts/All Relays Off"
                    M18 E ;ensure steppers are off before changing relays
                    G4 P100
                    M42 P0 S0
                    M42 P1 S0
                    M42 P2 S0
                    G4 P100
