    Duet 3 Sensorless Homing Issues
    • gspeterso
      gspeterso last edited by gspeterso
      I'm having some sensorless homing issues on a new machine using the Duet 3. I have played some with the sensitivity setting in the M915 command (tried -60 to 60). It actually never seems to report a stall. It does stall physically and starts to skipping. I'm unsure what else to try. Below is my config.
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Apr 27 2020 11:15:29 GMT-0500 (Central Daylight Time)
      M550 P"Printer" ; set printer name
      M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0.0 S0 ; physical drive goes backwards - (X)
      M569 P0.1 S0 ; physical drive goes backwards - (Y-Right)
      M569 P0.2 S1 ; physical drive goes forwards - (Y-Left)
      M569 P0.4 S1 ; physical drive goes forwards - (Z-Left)
      M569 P0.3 S1 ; physical drive goes forwards - (Z-Right)
      M569 P0.5 S1 ; physical drive goes forwards - (Extruder)
      M569 P1.0 S1 ; physical drive goes forwards - (Left PNP)
      M569 P1.1 S1 ; physical drive goes forwards - (Right PNP)
      M584 X0.0 Y0.1:0.2 Z0.4 U0.3 ; set drive mapping
      M350 X16 Y16 Z16 U16 I1 ; configure microstepping with interpolation
      M92 X53.33 Y53.33 Z100.00 U100.00 ; set steps per mm
      M566 X600.00 Y600.00 Z900.00 U900.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X90000.00 Y90000.00 Z10000.00 U10000.00 ; set maximum speeds (mm/min)
      M201 X2000.00 Y2000.00 Z1000.00 U1000.00 ; set accelerations (mm/s^2)
      M906 X1500 Y1500 Z1000 U1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X0 Y0 Z0 U0 S1 ; set axis minima
      M208 X885 Y385 Z60 U60 S0 ; set axis maxima
      M574 X1 S3 ; configure sensorless endstop for low end on X
      M574 Y2 S4 ; configure sensorless endstop for high end on Y
      M574 Z1 S3 ; configure sensorless endstop for low end on Z
      M574 U1 S3 ; configure sensorless endstop for low end on U
      ; Stall Detection
      M915 X S0 F0 R0 ; X axis stall detection
      M915 Y S0 F0 R0 ; Y axis stall detection
      M915 Z S0 F0 R0 ; Z axis stall detection
      M915 U S0 F0 R0 ; U axis stall detection
      M950 S0 C"io4.out" ; create servo pin 0 for BLTouch
      M558 P9 C"io4.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M308 S1 P"1.temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin 1.temp0
      M950 H1 C"1.out0" T1 ; create nozzle heater output on 1.out0 and map it to sensor 1
      M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
      M106 P0 C"Part_Fan" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
      M106 P1 C"Hotend" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
      M563 P0 S"3D_Head" D0 H1 F0 ; define tool 0
        Pay attention to the H parameter and the speed needed to detect the stall.
        https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing
        • gspeterso
          I think that was part of my issue. I found in another post that it only detects from a gcode file as well. I had just been sending G1 H1 commands from the console to test. I'm guessing that was my main issue. Thanks for the help!
            dc42 administrators @gspeterso last edited by
            @gspeterso said in Duet 3 Sensorless Homing Issues:
            It should work with G1 H1 commands from the console, as long as stall detection has been set up and the move is fast enough, and you have reduced the motor current if necessary (as you would normally do in the homing files when using stall detect homing).
            BTW I added this section to the wiki page on stall detection recently https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing#Section_Minimum_recommended_speed_for_stall_detection.
