    SOLVED! E0 Heater not accessible - Please help
    Firmware installation
    1
    • pro3dundefined
      pro3d
      Can you look through the config? - I can not access my nozzle heater anymore.
      M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
      M308 S1 P"e0temp" Y"pt1000" R4700 ; configure sensor 1 as PT1000 on pin e0temp
      M143 H1 S300 ; set temperature limit for heater 1 to 300C
      Valkyrie DIY High Temp 3D Printer
      R&D - Engineering Designer - Viking 3D Printers
      https://vkingprinter.com/
      • pro3dundefined
        pro3d
        Board: Duet WiFi 1.02 or later
        Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.0 (2020-01-03b3)
        Duet WiFi Server Version: 1.23
        • pro3dundefined
          pro3d
          My Tool settings was wrong I had S1 where it should have been H1
