    SOLVED Maestro upgrade to firmware 3 issues
    Firmware installation
    99
    • lyndon
      lyndon last edited by lyndon
      Hi All I am trying to upgrade my maestro to firmware v3. I have run the config tool to get my basic configuration. Formatted a new sdcard for this install. Copied the files configuration.zip from the config tool download to my /sys folder. downloaded DuetMaestroFirmware.bin and copied to my /sys folder. downloaded latest dwc and copied to /www folder. power up and open dwc but the firmware version is "Firmware: RepRapFirmware for Duet 2 Maestro 2.05.1 (2020-02-09b1)"
      The dwc is ver 2.1.5.
      So I tried download and then use dwc "Upload system files" and I get ``
      M997 S0
      Error: M997: In-application programming binary "iap4s.bin" not found
      Any help appreciated..
      • droftarts
        droftarts Moderator @lyndon last edited by
        @lyndon Copy "iap4s.bin" from https://github.com/dc42/RepRapFirmware/releases/tag/2.03 to your sys folder, then try. Note that you need to upgrade to 3.0 first, then to any of the 3.01 RC# versions.
        • PaulHew
          PaulHew last edited by PaulHew
          Here is the file you need.
          Just put it into your sys folder.
          HTH
          Paul.
          EDIT Ian beat me!
          RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
          Voron 2.4 disassembled..... Waiting for the RailCore Mini....
          • droftarts
            droftarts Moderator @PaulHew last edited by
            @PaulHew said in Maestro upgrade to firmware 3 issues:
            EDIT Ian beat me!
            Thwack!
            • lyndon
              Hi all and thanks for the replies I did try copying it from the my previous sd card. The upgrade seems to have worked, but I'm left with configuration issues now. lol. here we go back to the wiki and config tool..
              • droftarts
                @lyndon post your config.g, and what you're having problems with. Also, if you run your config.g with M98 P"sys/config.g" it will report errors it finds.
                  If you're going from 2 to 3 you should consider getting a fresh config from the online configurator to see what the major differences are.
                  As well as looking through this: https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
                  • lyndon
                    Thanks all for your replies I have it working now
