    Duet 3 + SBC: Random Freezes and Crashes
    476
    • fractalengineerundefined
      fractalengineer
      Here's a more major issue I've been having; the board randomly crashes
      The symptoms at first were shown through DWC disconnecting (orange message network disconnected)
      But then I started having gcode commands not going through (then orange message)
      Or even the tool temp not showing up on the graph; as if it didn't exist.
      But then It would also stop in the middle of a mesh leveling
      Then just now in the middle of a print; now that's not good.
      This time however I managed to connect to it through serial and run a M122; I hope someone can find it insightful and help me out with it:
      M122
      RepRapFirmware for Duet 3 MB6HC version 3.01-RC10 running on Duet 3 MB6HC v0.6 or 1.0
      Board ID: 08DJM-956L2-G43S4-6JTDA-3SS6L-1B76HUsed output buffers: 1 of 40 (10 max)
      Static ram: 154572
      Dynamic ram: 162452 of which 56 recycled
      Exception stack ram used: 520
      Never used ram: 75616
      Tasks: NETWORK(ready,2076) HEAT(blocked,1184) CanReceiv(suspended,3824) CanSender(suspended,1432) CanClock(blocked,1432) TMC(blocked,80) MAIN(running,4740) IDLE(ready,80)
      Owned mutexes:
      Last reset 00:05:19 ago, cause: software
      Last software reset at 2020-04-29 19:47, reason: User, spinning module LinuxInterface, available RAM 75632 bytes (slot 1)
      Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      Free file entries: 10
      MCU temperature: min 39.7, current 41.7, max 41.9
      Supply voltage: min 23.8, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
      Driver 0: standstill, reads 51726, writes 24 timeouts 0, SG min/max 0/506
      Driver 1: standstill, reads 51727, writes 24 timeouts 0, SG min/max 0/1023
      Driver 2: standstill, reads 51727, writes 24 timeouts 0, SG min/max 0/345
      Driver 3: standstill, reads 51728, writes 24 timeouts 0, SG min/max 0/216
      Driver 4: standstill, reads 51728, writes 24 timeouts 0, SG min/max 0/455
      Driver 5: standstill, reads 51733, writes 20 timeouts 0, SG min/max 0/1023
      Date/time: 2020-04-29 19:52:41
      Slowest loop: 5.28ms; fastest: 0.14ms
      Hiccups: 0(0), FreeDm: 375, MinFreeDm: 357, MaxWait: 93209ms
      === MainDDARing ===
      Scheduled moves: 252, completed moves: 252, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
      === AuxDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is ready with "M122" in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon* is idle in state(s) 0 0, running macro
      Code queue is empty.
      === Network ===
      Slowest loop: 1.64ms; fastest: 0.01ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
      HTTP sessions: 0 of 8
      - Ethernet -
      State: disabled
      Error counts: 0 0 0 0 0
      === CAN ===
      Messages sent 1251, longest wait 0ms for type 0
      === Linux interface ===
      State: 0, failed transfers: 0
      Last transfer: 97491ms ago
      RX/TX seq numbers: 0/6965
      SPI underruns 0, overruns 0
      Number of disconnects: 2
      Buffer RX/TX: 0/0-0
      ok
      Thanks!
      Railcore II ZL
      • Danalundefined
        Danal
        Please also post the output of this command run on the Pi
        apt show duetsoftwareframework
        fractalengineerundefined 1 Reply Last reply Reply Quote 0
        • A Former User?
          A Former User
          or apt list 2>/dev/null | grep "duet\|reprap" just to make sure its all on the up and up
            fractalengineer @Danal
            @Danal @bearer
            Of course; there you go:
            pi@duet3:~ $ apt show duetsoftwareframework
            Package: duetsoftwareframework
            Version: 2.1.1
            Priority: standard
            Section: electronics
            Maintainer: Duet3D Packaging Authority <pkg@duet3d.com>
            Installed-Size: unknown
            Depends: duetcontrolserver (= 2.1.1), duetsd (= 1.0.6), duettools (= 2.1.1), duetwebserver (= 2.1.0), duetwebcontrol (= 2.1.5), reprapfirmware (>= 2.1.1-1), reprapfirmware (<= 2.1.1-999)
            Homepage: https://pkg.duet3d.com
            Vcs-Git: https://github.com/chrishamm/DuetSoftwareFramework.git
            Download-Size: 1,706 B
            APT-Manual-Installed: yes
            APT-Sources: https://pkg.duet3d.com unstable/armv7 armhf Packages
            Description: Meta package for the full Duet software framework
            N: There are 25 additional records. Please use the '-a' switch to see them.
            pi@duet3:~ $ apt list 2>/dev/null | grep "duet\|reprap"
            duetcontrolserver/unstable,now 2.1.1 armhf [installed,automatic]
            duetruntime/unstable,now 2.1.1 armhf [installed,automatic]
            duetsd/unstable,now 1.0.6 all [installed,automatic]
            duetsoftwareframework/unstable,now 2.1.1 armhf [installed]
            duettools/unstable,now 2.1.1 armhf [installed,automatic]
            duetwebcontrol/unstable,now 2.1.5 all [installed,automatic]
            duetwebserver/unstable,now 2.1.0 armhf [installed,automatic]
            reprapfirmware/unstable,now 2.1.1-1 all [installed,automatic]
            Ps: I actually had to reset the PSU after the crash otherwise the Pi wouldn't show on network
            Railcore II ZL
            • chrishammundefined
              chrishamm administrators
              Please run another system update via
              sudo apt-get update
              sudo apt-get upgrade
              from SSH or a terminal on the Pi and this problem should be gone.
              Duet software engineer
              • Danalundefined
                Danal
                RC10 with duetsoftwareframework 2.1.1 has known crashes. You want RC10 with DSF 2.1.2.
                At this moment, that combo is the highest release available. Therefore, a normal
                sudo apt update
                sudo apt upgrade duetsoftwareframework
                will install this.
                • Danalundefined
                  Danal
                  Chris and I posted at the same time. We are saying the same thing (commands have same end result).
                  • Danalundefined
                    Danal
                    @bearer A (perhaps) slightly easier way to get the same thing. Note this was run on a machine with 2.0.0 installed.
                    apt list duet\*
                    Listing... Done
                    duetcontrolserver/unstable 2.1.2 armhf [upgradable from: 2.0.0]
                    duetruntime/unstable 2.1.2 armhf [upgradable from: 2.0.0]
                    duetsd/unstable,now 1.0.6 all [installed]
                    duetsoftwareframework/unstable 2.1.2 armhf [upgradable from: 2.0.0]
                    duettools/unstable 2.1.2 armhf [upgradable from: 2.0.0]
                    duetwebcontrol/unstable 2.1.5 all [upgradable from: 2.1.3]
                    duetwebserver/unstable 2.1.0 armhf [upgradable from: 2.0.0]
                    apt list reprap\*
                    Listing... Done
                    reprapfirmware/unstable 2.1.2-1 all [upgradable from: 2.0.0-1]
                      fractalengineer
                      Cool thank you @bearer @Danal and @chrishamm; I didn't know about the instability; everything's updated now, hopefully that fixes it!
                      Railcore II ZL
                        fractalengineer
                        Ok looks like it's much more stable now; the hotend heater still disappears from the graph and available sensor list every now and then but it doesn't stop it from running
                        It's just a bit nerve-racking to not have a way to monitor hotend temp at all times
                        Railcore II ZL
                          RRF 3.01-RC11, DWC 2.1.6 and DSF 2.1.3 are now available. If the hotend heater still disappears after installing that version, please start a new thread about it.
