    External trigger issue - RFF3.01 RC10
    Beta Firmware
    • felek
      felek last edited by
      I can't configure external trigger for trigger2.g.
      M950 J2 C"^1.io3.in"
      M581 P2 S1 T2 C0
      M950 works fine, when I type in console
      M950 J2
      I get proper input state, but something in wrong with M581.
      When I try to check external trigger using M582 T2 - state machine is Busy.
      Any ideas?
      I have Duet3 + expansion board
        What do you have in your trigger2.g file?
        • felek
          trigger2.g
          M291 P"Collision..."
          M112
          M999
          If endstop will we triggered I want to restart machine
            Please test again with the forthcoming 3.01-RC11 release (with the M581 C parameter changed to R).
            • Danal
              Danal last edited by Danal
              This is working for me on DSF 2.1.2 and RC10. Normally Open Pushbutton is physically wired to io6.in and gnd/
              ; Triggers
              M950 J10 C"!^0.io6.in"
              M581 P10 S0 T10
              trigger10.g
              M98 P"/macros/tool_unlock.g"
              T-1 P0
              Used when a tool is mounted and the machine cannot park it, most common when it has been reset and is not homed. Push the button, it releases the tool (so I can take it with my hand and return it to the parking stall).
              Anyway, I just set it up last night on RC10, and it works fine.
              • felek
                Thanks @Danal for tips but it still doesn't work for me. I only get "busy" state.
                I suppose that C parameter in M581 is problem. You didn't use this parameter
                @dc42 I upgraded(RC11) firmware and it works! Grat job!
                Danal 1 Reply Last reply Reply Quote 0
                • Danal
                  Danal @felek last edited by
                  @felek said in External trigger issue - RFF3.01 RC10:
                  Correct, define the pin with 950, then link to that with M581.
