RRF 3.01-RC11 DSF mode: io_1 not outputting "ok" consistently
Marlin mode and raw mode on io_1...
M555 P2 M575 P1 B115200 S2 M115 FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.01-RC11 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-04-30b3 ok G28 <should be an "ok" here> G91 ok G1 X0 Y0 ok Maybe something to do with having to go back to DSF for the homing macros?
Works OK in standalone mode.
Forgot to mention that this is a trivial issue. I just happened to run across it while I was testing the PanelDue.
@gtj0 said in RRF 3.01-RC11 DSF mode: io_1 not outputting "ok" consistently:
Not so trivial for users wanting to connect a GCode sender that requires the OK response. If the fix in trivial, I'll include it in 3.01 release. Thanks for reporting it.
This doesn't just affect the aux port in raw mode, it affects commands received by the Duet USB port too.
