    Duet Web Control 2.1.6
    Beta Firmware
    122
    • Lc1975
      Lc1975 last edited by
      Hello... Again..
      After updating to the last version of Firmware and DWC when homing the Z i have this:
      I update the Maestro bin file, then the DWC zip folder
      No error appears..
      Regards
        Send M558 and see what Z probe type it reports.
        • Lc1975
          With version 2.1.6
          M558
          Z Probe 0: type 0, dive height 5.0mm, probe speed 50mm/min, travel speed 6000mm/min, recovery time 2.00 sec, heaters normal, max taps 1, max diff 0.08
          version 2.1.5
          m558
          The problem is that the numbers disappear in the bar...
            Does it work properly with DWC 2.1.5 ?
            • Lc1975
              Yes.
              No problem with DWC 2.1.5
                Thanks, I'll refer this to @chrishamm to fix.
                • Lc1975
                  Thank you.
                  • chrishamm
                    chrishamm administrators last edited by
                    Thanks for reporting this, I'll fix it in DWC 2.1.7.
                    Duet software engineer
