    RRF 3.01-RC11 - Error: Bad command 97, 96, 192, 206
    Firmware developers
    • PaulHewundefined
      PaulHew
      Just hit the 'Emergency Stop' on my PanelDue and I get an error message as in the title.
      I received the additional error numbers everytime I push the E-Stop.
      Just pushed it again, now its 99.
      Console output, do not know if it relevant.
      01/05/2020, 14:34:35 Emergency Stop! Reset the controller to continue.
      01/05/2020, 14:34:35 Emergency stop, attemping to reconnect...
      01/05/2020, 14:33:52 Emergency Stop! Reset the controller to continue.
      01/05/2020, 14:33:52 Emergency stop, attemping to reconnect...
      01/05/2020, 14:33:35 Emergency Stop! Reset the controller to continue.
      01/05/2020, 14:33:35 Emergency stop, attemping to reconnect...
      01/05/2020, 14:33:01 Emergency Stop! Reset the controller to continue.
      01/05/2020, 14:33:01 Emergency stop, attemping to reconnect...
      01/05/2020, 14:30:45 m115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.01-RC11 ELECTRONICS: Duet Ethernet 1.02 or later + DueX5 FIRMWARE_DATE: 2020-04-30b3
      RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
      Voron 2.4 disassembled..... Waiting for the RailCore Mini....
        • What M575 command do you have in config.g?
        • What PanelDue firmware version are you using? It's reported on the Setup page of PanelDue.
        • PaulHewundefined
          PaulHew
          @dc42 Hi David
          M575 P1 B57600 S1 ; Comms parameters for PanelDue
          Updated the firmware in PanelDue yesterday to 1.24
          Kind Regards,
          Paul
