    DWC error: Your Duet rejected the HTTP request: page not found
    Duet Web Control
    128
    • Gabc1000
      Gabc1000 last edited by
      Basically I get a "Your Duet rejected the HTTP request: page not found" when I try to connect my Maestro to DWC.
      I am about at step 8 of the "Getting connected to you duet". I tried entering M503 and it gives me no error, M21 and it detects correctly my SD card, flashed the firmware on the SD card (unless I did it badly) but no results so far.
      Anybody can help?
      A Former User 1 Reply Last reply Reply Quote 0
      • A Former User
        A Former User @Gabc1000 last edited by
        @Gabc1000 said in DWC error: Your Duet rejected the HTTP request: page not found:
        M20 P/www shows the DWC files? if not download and put into /www
        • Gabc1000
          @bearer said in DWC error: Your Duet rejected the HTTP request: page not found:
          M20 P/www
          This is what I get
          • A Former User
            A Former User last edited by
            Looks about right for DWC2, could it be an old firmware on the Maestro that is trying to load DWC1 (aka reprap.htm.gz)?
            What does M115 output for version?
            • Gabc1000
              it gives me Version 2.01beta(RTOS)
              • A Former User
                Think that explains it, either update RRF to say 2.05.1 which is the latest or dowgrade DWC to v1
                • Gabc1000
                  reprap.htm.gz
                  Where can I find 2.05.1?
                  • A Former User
                    in general https://github.com/dc42/RepRapFirmware/releases/
                    https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md
                    https://github.com/dc42/RepRapFirmware/releases/tag/2.05.1
                    • Gabc1000
                      Somehow, I cant upgrade the firmware and I not understand why.
                      • Gabc1000
                        I was able to connect to DWC, I skipped a step in the firmware installation.
                        • A Former User
                          possible you woud have to do an intrim update, I don't have the complete overview but hte whats_new file should.
                            Were you able to get the firmware updated? If you can reliably get into the DWC you may need to update up through an intermediate release like 2.02 2.03 2.04 that has the IAP file for the maestro. If you try and update without the file it should tell you which you need.
                            Alternatively you could use the USB firmware flash procedure to update the firmware directly to your chosen release. You'll still need to have the proper IAP file present on the card for future updates via the normal DWC upload procedure.
                            https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_3
