SOLVED M117 and Conditional GCode Statements
M117 does not allow conditional gcode statements to be inserted into a string.
Standalone Duet 3
M117 {move.calibration.initial.deviation}
M117 hello {move.calibration.initial.deviation}
Actually, this combination works with M117
M117 {"Axis " ^ (move.axes[0].letter) ^ "not homed. Please wait while all axes are homed"}
BUT
When I added a space at the start of the second string it failed.
Then it worked.... sometimesM117 {"Axis " ^ (move.axes[0].letter) ^ " is not homed. Please wait while all axes are homed"}
Not sure if there's something screwy going on with caching in DWC here, but the same command sometimes works and sometimes doesn't
What if you enclose the hello in double quotes.
"hello"
I can confirm that the commands for the various dialog boxes (M117, M291 )etc don't accept conditional code.
I swear I posted about it in the firmware wish list but can't find it.I wouldn't call it a "bug"
Those command require a quoted string.BTW, your M117 example should be "hello" ^ {my_conditional_code}
But it still won't work
@OwenD It may have been moved to the Beta firmware forum
All of your posts should still show up in your user profile -
I asked about it in the DSF Development forum as well but never got an answer...
https://forum.duet3d.com/topic/15662/dsf-examples-for-code-expressions-are-now-preparsedDoesn't appear to work in standalone mode either.
BUT
HA!
Got it on M291
I swear I tried all this yesterdayM291 P{ "Axis " ^ (move.axes[0].letter) ^ " not homed. Continue?"} R"Check axis" S3
Thanks @OwenD, that works.
@OwenD said in M117 and Conditional GCode Statements:
DWC doesn't display a message if it was exactly the same as the previous one.
