    Problem with Laser filament sensor
    Filament Monitor
    89
    • Thalios
      Thalios last edited by
      Hello guys,
      I installed a laser filament sensor V2.0.
      Duet 3 6HC
      Wired with 3 wires, 3.3v, gnd and to the IN on IO5. Metered directly at the connector on the sensor, I get 3.3V properly.
      This is in my config.g:
      M591 D0 P5 C"io5.in" R40:120 E3 S0 A0
      The how to on the site says that there should be LEDs coming on. I have nothing at all.
      M591 D0 reports:
      Duet3D laser filament monitor v1 on pin io5.in, disabled, allow 40% to 120%, check every 3.0mm, no data received
      Should I plug it somewhere else?
      Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
      Heavily modified Ender 3 Pro (Duet 3 6HC)
      Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
      CR-10S Pro V2 (Duet 3 Mini 5+)
      and a bunch of SLA printers..
        Phaedrux Moderator @Thalios last edited by
        @Thalios said in Problem with Laser filament sensor:
        Check your wiring? When you say you checked at the connector on the sensor, did you also check at the end of the wiring run?
        • Thalios
          Yes, sorry, that's what I meant. I plugged it in and checked at the board side as well as on the sensor itself.
          Should the LEDs turn on as soon as power is applied?
            https://duet3d.dozuki.com/Wiki/Duet3dFilamentMonitor_LaserVersion#Section_Troubleshooting
            It would seem that way, yes.
            What firmware version are you running?
              Might also want to try a different pin.
              • Thalios
                3.01RC10.
                I'll try with a different connection tonight
                • Thalios
                  I'm an idiot. I had a wire that was cut (gnd).
                  Now getting this:
                  Duet3D laser filament monitor v2 on pin io5.in, disabled, allow 40% to 120%, check every 3.0mm, version 2, quality 221, brightness 24, shutter 136, measured min 90% avg 98% max 101% over 3457.5mm
                  Is that normal for Yellow AMZ3D PLA 1.75mm?
                  Thanks!! Sorry for the trouble!
                    dc42 administrators @Thalios last edited by
                    Now getting this:
                    Yes, that looks good.
