    Problem with duet 3 firmware
    Firmware installation
    66
    • Dad003
      Dad003 last edited by
      Well i was building a new printer with a Duet 3 , after i followed the step i was able to connect to YAT and get the command for the version and IP , tried to access the duet web page but couldn't was getting an error 10 ,
      Readed how to solve this decided to erase the firmware and start over , following step again now the DIAG led stay red , trying to reinstall firmware but Bossa or YAT will not do anything , i get the COM port on , but nothing happen
      looking at the peripheral i get bossa port,
      ![https://i46.servimg.com/u/f46/11/37/22/78/bossa10.png](image url)
      looking in the wiki there there like multiple page using different software and him lost so i need help
      • A Former User
        A Former User last edited by
        Should have worked, could be a bad usb cable or possibly a bug in the bossa program.
        Try a different USB cable or two, or if it still fails maybe try the alternative SAM-BA software?
        • Dad003
          IT a brand new cable that i just bough a few hours ago and it was working fine not too long ago
          • Danal
            Danal last edited by
            It may be necessary to erase, and or erase then reset (tiny button on edge) several times.
            • Dad003
              i might have fix my issue , i eneded selecting a older firmware file and bossa was able to install it this time
              • A Former User
                Could you post which version failed and which worked?
                • Dad003
                  tried the last one , and it wasnt working , so i tried the one that was like a week old ,
                  now him still impossible to acces the web control tool
                  • A Former User
                    did you download DuetWebControl and put on /www on the SD card?
                    • Dad003
                      Got it to work finally , file were on the sd card just not in the proper folder it seem ,
                      thank for the helps
                      • A Former User
                        Glad it worked out; @droftarts or one of the other BOSS'es might wanna look into if there is a difference between RC11 and RC10 when it comes to failing to flash, or just coincidence?
