    problem with filament sensor
    372
    • Thomas25undefined
      Thomas25
      Hi
      I did not manage to install the filament sensor on my machine. My machine is a core xy and see attached my configuration.
      the sensor powers on and switches on the mother board led light when it actions. Should I modify another folder ?
      Thanks in advance for wour help.
      Thomas
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sat Feb 29 2020 13:14:14 GMT+0100 (heure normale d’Europe centrale)
      G90                                             ; send absolute coordinates...
      M83                                             ; ...but relative extruder moves
      M550 P"ngen thom"                               ; set printer name
      M669 K1                                  ; switch to CoreXY mode
      M552 S1                                         ; enable network
      M586 P0 S1                                      ; enable HTTP
      M586 P1 S0                                      ; disable FTP
      M586 P2 S0                                      ; disable Telnet
      M569 P0 S0                                      ; physical drive 0 goes backwards
      M569 P1 S1                                      ; physical drive 1 goes backwards
      M569 P2 S0                                      ; physical drive 2 goes backwards
      M569 P3 S1                                      ; physical drive 3 goes forwards
      M569 P4 S0                                      ; physical drive 4 goes backwards
      M584 X0 Y1 Z2 E3:4                              ; set drive mapping
      M350 X16 Y16 Z16 E16:16 I1                      ; configure microstepping with interpolation
      M92 X160.00 Y160.00 Z800.00 E830.00:830.00      ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00:120.00      ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00:250.00      ; set accelerations (mm/s^2)
      M906 X1100 Y1100 Z1400 E800:800 I30             ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                         ; Set idle timeout
      M208 X0 Y0 Z0 S1                                ; set axis minima
      M208 X300 Y330 Z300 S0                          ; set axis maxima
      M574 X1 S1 P"xstop"                             ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                             ; configure active-high endstop for low end on Y via pin ystop
      M950 S0 C"exp.8"                                ; create servo pin 0 for BLTouch
      M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000   ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X35 Y2 Z1.7                            ; set Z probe trigger value, offset and trigger height
      M557 X15:300 Y15:300 S30                        ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138  ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                           ; create bed heater output on bedheat and map it to sensor 0
      M143 H0 S120                                    ; set temperature limit for heater 0 to 120C
      M307 H0 B0 S1.00                                ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                         ; map heated bed to heater 0
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138   ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                            ; create nozzle heater output on e0heat and map it to sensor 1
      M143 H1 S280                                    ; set temperature limit for heater 1 to 280C
      M307 H1 B0 S1.00                                ; disable bang-bang mode for heater  and set PWM limit
      ; run-out filament detector
      M591 D0 P2 C"zstop" S1                          ; sensor for extruder 0, simple sensor (low signal when filament present) on Z endstop
      M950 F0 C"fan0" Q500                            ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                  ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                            ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                               ; set fan 1 value. Thermostatic control is turned on
      ;Pressure Advance
      M572 D0 S0.2                                    ;enable pressure advance
      ;Jerk
      M566 X720 Y720 Z20 E400                         ;jerk
      M563 P0 D0 H1 F0                      ; Define tool 0
      G10 P0 X0 Y0 Z0                          ; Set tool 0 axis offsets
      G10 P0 R0 S0                             ; Set initial tool 0 active and standby temperatures to 0C
      M567 P0 E0.5:0.5                         ;set mixing ratios for tool 0
      ; Bed temperature
      M140 S0 R0                              ; Set initial bed active and standby temperatures to 0C
      ; Automatic saving after power loss is enabled
      M911 S21.0 R23.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
      ; Calibrate MCU Temperature
      M912 P0 S6.0                                 ; calibrate CPU temperature
      ; Custom settings are defined
      M501
      • piperswundefined
        pipersw
        What is the error message displayed ?
        • Thomas25undefined
          Thomas25
          M591 d0 in duet contrôle "extrudeur has no filament sensor"
          • ChrisPundefined
            ChrisP
            Have you tried putting the M591 after you've setup the tools?
            • Thomas25undefined
              Thomas25
              still same issue, whit m591 d0 in console, no run-out filament detecto
              ;Pressure Advance
              ;Jerk
              ;M568 P0 S1        plus utile dans RRF3         ; enable mixing for tool 0
              ; Bed temperature
              M501
                Which firmware version are you using? If you are using 3.0 then please upgrade to 3.01-RC11.
                • Thomas25undefined
                  Thomas25
                  thank you, i test this
                  • Thomas25undefined
                    Thomas25
                    thank you very much, the sensor is ok. I'm very happy
