    RRF 3.01-RC11 Network Hibernating
    Beta Firmware
    1
    1
    36
    • Dr_Ju_Ju
      Dr_Ju_Ju last edited by
      It's probably just my system, & I looked on the release notes, to see if there was anything, but....
      I've had this occur on 3 occasions now, and only since updating to RC11, that the printer appears to be fully working, and can run everything from the Panel Due, but the web\network interfaces appear to have gone into a 'hibernation' state where no browser can connect, neither will the Duet respond a ping\telnet etc.
      This appears to occur approx. 20 mins following a print, and the only way I can get back to a contactable system is either issue a 'STOP' command, on the Panel Due, or a power cycle.
      No changes have been made to the Config files.
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC11 running on Duet Ethernet 1.02 or later
      Board ID: 08DGM-95BNL-MGPSJ-6J1F2-3SD6L-9JZHXUsed output buffers: 3 of 24 (20 max)
      Static ram: 28060
      Dynamic ram: 93204 of which 44 recycled
      Exception stack ram used: 256
      Never used ram: 9508
      Tasks: NETWORK(ready,176) HEAT(blocked,1228) MAIN(running,1828) IDLE(ready,76)
      Owned mutexes:
      Last reset 00:02:46 ago, cause: software
      Last software reset at 2020-05-04 20:32, reason: User, spinning module GCodes, available RAM 9212 bytes (slot 2)
      Error status: 0
      MCU temperature: min 31.8, current 33.0, max 33.8
      Supply voltage: min 24.2, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
      Date/time: 2020-05-04 20:35:00
      Cache data hit count 305150093
      Slowest loop: 146.97ms; fastest: 0.13ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.8ms, write time 44.9ms, max retries 0
      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === MainDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
      === AuxDDARing ===
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 233.11ms; fastest: 0.02ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 2 of 8
      Interface state active, link 100Mbps full duplex
      === DueX ===
      Read count 0, nan reads/min
      Julian,
      Old goat, learning new things….
