    Problem with Tool Fan
    • toddelundefined
      toddel
      Hi.
      i have a problem with my tool fan...
      I want it to run with 100% after Hotend is over 45°C.
      While printing the fan goes down to 15 like the part cooling fan...
      What did i wrong?
      M950 F0 C"out7" Q10                          ; create fan 0 on pin out7 and set its frequency
      M106 P0 C"Hotend" S1.0 T45 H1                ; set fan 0 name and value. Thermostatic control is turned on (45°)
      M950 F1 C"out8" Q10                          ; create fan 1 on pin out8 and set its frequency
      M106 P1 C"Radial" S0 H-1                     ; set fan 1 name and value. Thermostatic control is turned off
      M563 P0 S"Mosquito" D0 H1 F0                 ; define tool 0
        How do you have the fans wired?
        • aidarundefined
          aidar
          You messed up your fan definitions and terminology. Tool fan is part cooling fan, not hotend fan. As i see from your config, your "Radial" fan is part cooling fan, so you should define that fan with tools. Change F0 in M563 to F1 and try again.
          • toddelundefined
            toddel
            Hotend Fan should be named as Heatbreak Fan... Radial is the part cooling fan
