    Where does the temperature daughter board go on Duet3?
    • Kulitorumundefined
      Kulitorum
      I can't find anything in any documentation - Where do I install it, and in what orientation?
      Tried this - it seemed logical, is this correct?
      I'm connecting it to a Ultimaker K-Type thermocoupler - is my configuration correct?
      M308 S0 P"spi.cs0" Y"thermocouple-max31855" ; configure sensor 0 as thermocouple via CS pin spi.cs0
      M308 S1 P"spi.cs1" Y"thermocouple-max31855" ; configure sensor 1 as thermocouple via CS pin spi.cs1
      M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
      Thank you.
      • aidarundefined
        aidar
        From your picture, you are using Pt100 daughterboard. As far as i know, thermocouple needs another daughterboard, for thermocouple. Pt100 board will not work with thermocouples.
        https://duet3d.dozuki.com/Wiki/Thermocouple_daughter_board
          Kulitorum
          Thank you - turns out the UM2 does not use Thermocoubles, but a PT100 RTD (Resistance Temperature Detectors) Device, so I did have the correct daughter board, I just had to short the solder pins (red circles) and my config (that works) is:
          M308 S0 P"spi.cs0" Y"rtd-max31865" ; configure sensor 0 as thermocouple via CS pin spi.cs0
          M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
            Have you seen this?
            https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors
