    How to build the bin file?
    Firmware developers
    942
    • Jimmykcundefined
      Jimmykc
      I want to modify the source code and increase new M code for new function.
      I have refer to the buildinstructions.md, but I can’t build the bin file.
      https://github.com/dc42/RepRapFirmware/blob/v3-dev/BuildInstructions.md.
      I have questions below :
      1. The current source code is on these branches : RepRapFirmware, CoreNG, FreeRTOS, RRFLibraries, DuetWiFiSocketServer. Which branches is necessary if I use Duet3 as a standalone board (No Pi)?
      2. How do I use eclipse IDE tool to build the bin file? Could you have the training video about eclipse for freshman? Thanks.
      • A Former User?
        A Former User
        no video but this post may help with cloning the different repositories.
        after step 6.
        @bearer said in Building RRFlibraries 'atomic_uint8_t' does not name a type:
         cd /c/eclipse/firmware
        git clone https://github.com/dc42/CoreNG.git --branch dev
        git clone https://github.com/dc42/CANlib.git
        git clone https://github.com/dc42/RRFLibraries.git --branch dev
        git clone https://github.com/dc42/FreeRTOS.git
        git clone https://github.com/dc42/RepRapFirmware.git --branch v3-dev
        git clone https://github.com/dc42/DuetWiFiSocketServer.git
        then proceed and read the instructions carefully especially step 14.
        14 Build CoreNG first, also build FreeRTOS and RRFLibraries if needed. Then clean and build RepRapFirmware (the clean step is needed to make Eclipse notice that the output library files in the other projects have been built).
        and the rest of step 14 on how to set configuration to build for the board of your chosing
        (caveat emptor; the aboce may be stale, but the build instructions should be valid still, just needs careful reading)
        Jimmykcundefined 1 Reply Last reply Reply Quote 0
        • Jimmykcundefined
          Jimmykc @A Former User
          @bearer I do step 14 and build CoreNG first, then eclipse show error below:111.jpg
          Could you tell me what step I set wrong ? Thanks.
            I think you haven't correctly done step 13 in the build instructions file.
            • Jimmykcundefined
              Jimmykc @dc42
              @dc42 I have done the step 13 to build variables. The result show below.222.jpg
              Sorry, I can’t find out what wrong 13 step is. So could you tell ? Thanks.
                Confirm that you are using the dev branch of CoreNG? The project settings should look like this:
                • Jimmykcundefined
                  Jimmykc @dc42
                  @dc42 Confirm that you are using the dev branch of CoreNG?
                  => I download the CoreNG-1.19 file, then rename folder CoreNG-1.19 in that folder to CoreNG.
                  But I open the project settings, it show below
                  I don’t modify any setting. Why is my setting different from your setting ?
                  Then I follow your setting, but the result is same. It show 3 errors.
                  • A Former User?
                    A Former User @Jimmykc
                    @Jimmykc said in How to build the bin file?:
                    thats 3 years old, you need the dev branch and a current version. imho easiest to use git git clone https://github.com/dc42/CoreNG.git --branch dev
                    but you could try downloading this https://github.com/dc42/CoreNG/archive/dev.zip
                    • Jimmykcundefined
                      @bearer I download the CoreNG-dev, FreeRTOS-master, and RRFLibraries-dev, then I build them. The eclipse show no error and no warning.666.jpg
                      When I increase the RepRapFirmware-3.01-RC9 file to the project, I build them.
                      The eclipse show 32 errors and 2 warnings.
                      I re-check the step 14, but I don’t know what the meaning of “Then clean and build RepRapFirmware (the clean step is needed to make Eclipse notice that the output library files in the other projects have been built)” is.
                        dc42 administrators @Jimmykc
                        Right click on the project and select Clean form the drop-down menu.
                        • Jimmykcundefined
                          Jimmykc @dc42
                          @dc42 I refer to your suggestions, but I have a questions.
                          Do I need to import to the file “DuetWiFiSocketServer” if I want to use Duet3 MB6HC and expansion board 3HC as a standalone board. (No Pi) ?
                            You don't need DuetWiFiSocketServer to build Duet 3 firmware.
                            Latest RRF 3.01-RC source is currently on branch v3.01-dev of RepRapFirmware. The v3 branch is a few commits older.
                            • Jimmykcundefined
                              Jimmykc @dc42
                              I right click on the project and select build configuration -> Set Active -> Duet3_V06_CAN0.
                              I build it, but I fail.
                              log.txt
                                The versions of the CoreNG and RepRapFirmware projects you are using are slightly mismatched. Try updating both of them.
                                • Jimmykcundefined
                                  Jimmykc @dc42
                                  @dc42 I update CoreNG and RepRapFirmware projects. The previous problem has be fixed but show a new error.
                                  log2.txt
                                  I re-build the project again, and the error will not appear.
                                    You can find crc32appender.exe under the Tools folder of the RepRapFirmware repository. Copy it on to your PC and add it to the PATH.
                                    • Jimmykcundefined
                                      Jimmykc @dc42
                                      @dc42 I paste the crc32appender.exe on my path.
                                      I fixed all problems. Thank you, but I have the last question.
                                      Is the bin file for main board if I select build configuration -> Set Active -> Duet3_V06?
                                      Is the bin file for expansion board if I select build configuration -> Set Active -> Duet3_V06_CAN0 ?
                                        The _CAN0 one is just a test configuration so that we can test the second CAN port, which the standard firmware doesn't use. Use the Duet3_V06 configuration.
                                        To build expansion board firmware, import project Duet3Expansion into your workspace and build that project.
                                        • Jimmykcundefined
                                          Jimmykc @dc42
                                          @dc42 Now I know how to build the bin file. Thanks you so much.
                                          • arhiundefined
                                            arhi
                                            @dc42 this still stands for RRF3.1 ?
                                            to build firmware version 2.03beta3 and later use version 2018-q4-major
                                            or you moved to 2020 version maybe?
