    How to build the bin file?
    Firmware developers
    956
    • Jimmykcundefined
      Jimmykc @A Former User
      @bearer I do step 14 and build CoreNG first, then eclipse show error below:111.jpg
      Could you tell me what step I set wrong ? Thanks.
        I think you haven't correctly done step 13 in the build instructions file.
        Jimmykcundefined 1 Reply Last reply Reply Quote 0
        • Jimmykcundefined
          Jimmykc @dc42
          @dc42 I have done the step 13 to build variables. The result show below.222.jpg
          Sorry, I can’t find out what wrong 13 step is. So could you tell ? Thanks.
            Confirm that you are using the dev branch of CoreNG? The project settings should look like this:
            • Jimmykcundefined
              Jimmykc @dc42
              @dc42 Confirm that you are using the dev branch of CoreNG?
              => I download the CoreNG-1.19 file, then rename folder CoreNG-1.19 in that folder to CoreNG.
              But I open the project settings, it show below
              I don’t modify any setting. Why is my setting different from your setting ?
              Then I follow your setting, but the result is same. It show 3 errors.
                A Former User @Jimmykc
                @Jimmykc said in How to build the bin file?:
                thats 3 years old, you need the dev branch and a current version. imho easiest to use git git clone https://github.com/dc42/CoreNG.git --branch dev
                but you could try downloading this https://github.com/dc42/CoreNG/archive/dev.zip
                • Jimmykcundefined
                  @bearer I download the CoreNG-dev, FreeRTOS-master, and RRFLibraries-dev, then I build them. The eclipse show no error and no warning.666.jpg
                  When I increase the RepRapFirmware-3.01-RC9 file to the project, I build them.
                  The eclipse show 32 errors and 2 warnings.
                  I re-check the step 14, but I don’t know what the meaning of “Then clean and build RepRapFirmware (the clean step is needed to make Eclipse notice that the output library files in the other projects have been built)” is.
                    dc42 administrators @Jimmykc
                    Right click on the project and select Clean form the drop-down menu.
                    • Jimmykcundefined
                      Jimmykc @dc42
                      @dc42 I refer to your suggestions, but I have a questions.
                      Do I need to import to the file “DuetWiFiSocketServer” if I want to use Duet3 MB6HC and expansion board 3HC as a standalone board. (No Pi) ?
                        You don't need DuetWiFiSocketServer to build Duet 3 firmware.
                        Latest RRF 3.01-RC source is currently on branch v3.01-dev of RepRapFirmware. The v3 branch is a few commits older.
                        • Jimmykcundefined
                          Jimmykc @dc42
                          I right click on the project and select build configuration -> Set Active -> Duet3_V06_CAN0.
                          I build it, but I fail.
                          log.txt
                            The versions of the CoreNG and RepRapFirmware projects you are using are slightly mismatched. Try updating both of them.
                            • Jimmykcundefined
                              Jimmykc @dc42
                              @dc42 I update CoreNG and RepRapFirmware projects. The previous problem has be fixed but show a new error.
                              log2.txt
                              I re-build the project again, and the error will not appear.
                                You can find crc32appender.exe under the Tools folder of the RepRapFirmware repository. Copy it on to your PC and add it to the PATH.
                                • Jimmykcundefined
                                  Jimmykc @dc42
                                  @dc42 I paste the crc32appender.exe on my path.
                                  I fixed all problems. Thank you, but I have the last question.
                                  Is the bin file for main board if I select build configuration -> Set Active -> Duet3_V06?
                                  Is the bin file for expansion board if I select build configuration -> Set Active -> Duet3_V06_CAN0 ?
                                    The _CAN0 one is just a test configuration so that we can test the second CAN port, which the standard firmware doesn't use. Use the Duet3_V06 configuration.
                                    To build expansion board firmware, import project Duet3Expansion into your workspace and build that project.
                                    • Jimmykcundefined
                                      Jimmykc @dc42
                                      @dc42 Now I know how to build the bin file. Thanks you so much.
                                      • arhiundefined
                                        arhi
                                        @dc42 this still stands for RRF3.1 ?
                                        to build firmware version 2.03beta3 and later use version 2018-q4-major
                                        or you moved to 2020 version maybe?
                                          For 3.1.1 I used version 9-2019q4-major. But I see that 9-2020-q2-update is now available, so I'll probably switch to that for 3.2.
                                          arhiundefined 1 Reply Last reply Reply Quote 1
                                          • arhiundefined
                                            arhi @dc42
                                            @dc42 nice, I recompiled it on mac, was faster to get everything up and running without messing out working envinronments for other stuff on my main win desktop and compiling is fast enough that the speed of the mac is not that important 😄 .. brew is a nice addon to osx 🙂 .. brew installs (GNU Tools for Arm Embedded Processors 9-2019-q4-major) 9.2.1 20191025 (release) [ARM/arm-9-branch revision 277599] so exactly what you say you are using for 3.1.1 and the issue is only with src/GCodes/GCodeBuffer/ExpressionParser.cpp the conv.Accumulate is called with wrong number of parameters .. probbly ReprapFirmware:v3-dev vs RRFLibraries:dev at point I was doing a clone were out of sync (I see that whole section is new) ... I just needed to do the quick read of the ADC so I removed that whole section and compiled without a problem 😄 .. got data I needed I returned release 3.1.1. 🙂 ..
                                            I moved to 2020 myself for few projects and so far did not notice any issues
