SOLVED Move outside axis limit is not stopped
Pic pretty much says it all. Axis limit max 330. Moves right past it. Oh, and it is not the -10. It will go to 345 or 350 or whatever, just as happily.
What am I missing? or misconfiguring?
Board: Duet 3 MB6HC (MB6HC)
DSF Version: 2.1.3
Firmware: RepRapFirmware for Duet 3 MB6HC 3.01-RC11 (2020-04-30b3)
Duet Web Control 2.1.6
Send M564 S1 and then try.
M564 S0 will disable.
M564 is on the screen in the original shot.
Nonetheless, just for completeness, I issued it again. No change in behavior.
No issue here...
M115: FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.01-RC11+1 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-05-02b2 M208: Axis limits X-235.0:235.0, Y-235.0:235.0, Z0.0:420.0
Can't move beyond 235 with either a relative or absolute move.
Something to do with the asymmetrical limits maybe? What happens if you set the limit to 0:330?
Or just for a test -10:10
What are your machine positions and do you have any tool offset? Click on "Tool Position" to show the machine coordinates.
Aha! Thank you Chris. Yes, there are tool offsets. And sure enough, it stops at machine 330.
I can adapt my particular use case, now that I know how this works. And FANTASTIC that clicking on Tool Position toggles to Machine Position. Very VERY useful.
