    Max input voltage on sensor inputs 1LC toolboard
    • j.dewitundefined
      j.dewit
      I was wondering what the Maximum voltage is that the 1LC toolboard can withstand on its inputs? Since we are using 10-30v inductive sensors.
      I was planning to power them using one of the 12v outputs on the toolboard.
      I was unable to find this in the specifications.
      • aidarundefined
        aidar
        Looks like "Power in 12 -32V" is clearly visible on wiring diagram.
        https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board
        • j.dewitundefined
          j.dewit
          Thanks but I meant the input voltage of the sensor inputs, io.0.in and io.1.in.
          On the Duet 3 Mainboard these are rated to 30v.
            IO_0_IN max 30V.
            IO_1_IN max 13V.
