Error on 'apt-get install duetsoftwareframework'
During the setup of my RPi 4b when I try to run the 'apt-get install duetsoftwareframework' I get the following error messages:
E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
@QIDI-Xmax_upgrade said in Error on 'apt-get install duetsoftwareframework':
sudo
as in
sudo apt-get install duetsoftwareframework
sudo is missing from the getting started page on that line :
sudo apt-get install apt-transport-https
sudo apt-get update
apt-get install duetsoftwareframeworkCheers
C
@Carlo said in Error on 'apt-get install duetsoftwareframework':
sudo is missing
thanks for taking the time to post; its been added so the next guy hopefully has one less problem.
Thanks Carlo!
Now when I run the 'apt-get install duetsoftwareframework' command it runs but I am getting the following error:
pi@raspberrypi:~ $ sudo apt-get install duetsoftwareframework
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package duetsoftwareframework
pi@raspberrypi:~ $
are you using the DuetPi image, orhave you enabled the duet3d package repository and ransudo apt update
after adding the duet3d package repository?maybe trimming the instructions down helps?
#get key wget -qO - https://pkg.duet3d.com/duet3d.gpg | sudo apt-key add - #get list wget -qO - https://pkg.duet3d.com/duet3d.list | sudo tee /etc/apt/sources.list.d/duet3d.list #update sudo apt update
