SOLVED 3.01RC12 on Ethernet + Duex5, M291 S2 nonblocking inside IF loop
Potential bug: M291 S2 option is blocking and working correctly in Duet Ethernet + Duex5 as long as it is outside of a conditional IF statement. Once it is used inside an IF statement, S2 option is no longer blocking.
RRF3 notes only states only nonblocking M291 options are available in Duet3+SBC.
Thanks, added to my list to investigate.
Can you post the macro?
Board: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.01-RC12 (2020-05-06b1)
Duet WiFi Server Version: 1.23
Duet Web Control 2.1.7M291 S2 is definitely blocking inside macro when run from DWC or called with M98
Haven't tried running withing a print file.while iterations < 6 if mod(iterations+1,2)!=0 echo "odd number" M291 P{iterations+1 ^ " is an odd number"} R"Odd number" S2 else echo "even number" M291 P{iterations+1 ^ " is an even number"} R"Even number" S2 G4 S0.5 if !move.axes[0].homed M291 P"axis is not homed (IF)" R"check" S2 elif move.axes[1].homed M291 P"axis 1 is homed, but not 0 (ELIF)" R"check" S2 else M291 P"axis is not homed (ELSE)" R"check" S2
@OwenD said in 3.01RC12 on Ethernet + Duex5, M291 S2 nonblocking inside IF loop:
Uhm, odd, its working for me now as well. Could have sworn it wasn't behaving correctly yesterday. Thanks for the confirmation! Will have to go back and see what i did wrong.
Edit:
This is what was tripping me up. I wasn't seeing the M117 message pop up on the PanelDue after M291, so I thought it was running ahead.
elif state.currentTool = 1 ; SOME CODE HERE M300 ; beep M83 ; set extruder to relative moves G1 E-250 F2000 ; unload fast M300 ; beep M291 P"Please clear filament guide tube of old material!" S2 G4 S1 ; Wait 1 second M117 "Start feeding filament into LT Tool!" G4 S2 ; Wait 2 seconds ; SOME OTHER CODE
@techild
Glad you're sorted.
Might be best to mark thread as solved.
