    Script to measure printer volume (max/min stops required)
    1
    100
    • mwwhitedundefined
      mwwhited
      I just use dual limit switches but I guess the same thing would work with stall guard
      I wanted the ability to measure out my machines volume once I complete my interchangeable bed. If your max volume is larger you will need t o adjust the second M208 as well as the G1 H3. You can probably also get away with not having the second minimum homing step... I do this to ensure any minor overshoot on the high end doesn't skew anything.
      Measure All
      G91				; relative positioning
      M208 X0 Y0 Z0 S1		; minimum to 0
      M208 X250 Y250 Z250 S0		; maximum to 250
      ;home min
      M574 X1 Y1 Z1 S1		; set low endstops
      G1 X-250 Y-250 Z-250 H1 F1800	; Home to 0 "quickly"
      G1 X5 Y5 Z5 F360		; back off endstops
      G1 X-250 Y-250 Z-250 H1 F360	; Home to 0 "slowly"
      ; measure max
      M574 X2 Y2 Z2 S1		; set high endstops
      G1 X300 Y300 Z300 H3 F1800	; measure XYZ
      G1 X-5 Y-5 Z-5 F360		; back off endstop
      ;home min
      G90               		; absolute positioning
      G0 X{move.axes[0].max/2} Y{move.axes[1].max/2} Z{move.axes[2].max/2} F20000	; move center
      M208
