Error: M350: Driver 20 does not support x8 microstepping
I have been going nuts trying to get my quad Z motors configured right. I thought I had everything figured out but now I am getting the error:
Error: M350: Driver 20 does not support x8 microsteppingThe extruder was moved to my toolboard at 20.0 and I did not specify interpolation but it gives me the error as if I did.
See my config below. Can someone tell me what I need to change?
; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Apr 28 2020 11:01:38 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"BAP" ; set printer name; Drives
M569 P0.1 S0 ; physical drive 0.1 goes backwards
M569 P0.2 S0 ; physical drive 0.2 goes backwards
M569 P0.3 S0 ; physical drive 0.3 goes backwards
M569 P0.4 S0 ; physical drive 0.4 goes backwards
M569 P0.5 S1 ; physical drive 0.5 goes forwards
M569 P20.0 S0 ; physical tool board drive 20.0 goes backwards; Motor remapping for quad Z
M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E0.20 ; set drive mapping
M671 X-125:825:745:-125 Y0:0:835:835 S10 F1 ;lead screws clockwise front right z1, front left z2, rear left z3, rear right z4
M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
M350 E8 ; Set Extruder to 8x Microstepping with no interpolation
M92 X64 Y64 Z400 E409 ; Set steps per mm
M566 X500.00 Y500.00 Z24.00 E24.00 ; set maximum instantaneous speed changes (mm/min)
M203 X10000 Y10000 Z600 E3600 ; Set maximum speeds (mm/min)
M201 X3000 Y3000 Z250 E120 ; Set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E1000 I75 ; Set motor currents (mA) and motor idle factor in %
M84 S3000 ; Set idle timeout; Axis Limits
M208 X760 Y690 Z800 S0 ; set axis maxima; Endstops
M574 X1 S1 P"io1.in" ; configure active-high endstop for low end on X via pin io1.in
M574 Y1 S1 P"io2.in" ; configure active-high endstop for low end on Y via pin io2.in
M574 Z1 S2 ; configure Z-probe endstop for low end on Z;M574 Z1 S1 P"io3.in" ; old z min configure active-high endstop for low end on Z via pin io3.in
M950 S0 C"20.io0.out" ; create servo pin 0 for BLTouch
M558 P9 C"20.io0.in" H10 F120 T13000 ; set Z probe type to bltouch and the dive height + speeds
G31 P25 X-15 Y-40 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X30:765 Y50:700 S200; Heaters
; old M308 S1 P"20.temp0" Y"thermistor" T100000 B4725
M308 S1 P"20.temp0" Y"thermistor" R2200 T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 20.temp0
M950 H0 C"20.out0" T1 ; create nozzle heater output on 20.out0 and map it to sensor 0
M143 H0 S300 ; set temperature limit for heater 0 to 280C
M307 H0 A400 C250.0 D18 B0 V13.4; Fans
M950 F0 C"20.out2" ; Tool board hot end fan
M106 P0 C"Hot End fan" S1 H1 T45 ; set fan 0 name and value. Thermostatic control is turned on
M950 F1 C"20.out1" ; Tool board print cooling fan, no tacho
M106 P1 C"Part Cooler" S0 ; set fan 1 value. Thermostatic control is turned off; Tools
M563 P0 D0 F0 H0 ; define tool 0
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings
Which firmware versions are you using, both on the main board and the tool board? Current is 3.01-RC12 on main board and 3.01-RC11 on tool board.
@dc42 rc11 on main and tool board
@jdumoulin
The extruder will not move even if I take interpolation out for the other drives.
@jdumoulin said in Error: M350: Driver 20 does not support x8 microstepping:
E0.20
Scratch all that. I finally found the typo. Im sorry to have wasted your time on this. I checked this thing over and over.
Extruder was listed as E0.20 instead of E20.0
