    DSF 2.2.0 long comments in gcode causes an exception
    DSF Development
    • gloomyandyundefined
      gloomyandy
      Hi, if I attempt to print or simulate a file with a long comment line I get an exception and the print/simulation is cancelled. The exception is given below:
      May  8 21:06:40 duet3 DuetControlServer[1908]: [info] Starting file print
      May  8 21:06:40 duet3 DuetControlServer[1908]: [error] Code ;12345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890 has thrown an exception
      May  8 21:06:40 duet3 DuetControlServer[1908]:    System.ArgumentException: Failed to serialize code
      May  8 21:06:40 duet3 DuetControlServer[1908]:  ---> System.ArgumentException: Destination is too short. (Parameter 'destination')
      May  8 21:06:40 duet3 DuetControlServer[1908]:    at DuetControlServer.SPI.Serialization.Writer.WriteCode(Span`1 to, Code code) in /home/pi/DuetSoftwareFramework/src/DuetControlServer/SPI/Serialization/Writer.cs:line 133
      May  8 21:06:40 duet3 DuetControlServer[1908]:    at DuetControlServer.SPI.DataTransfer.GetCodeSize(Code code) in /home/pi/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 523
      May  8 21:06:40 duet3 DuetControlServer[1908]:    --- End of inner exception stack trace ---
      May  8 21:06:40 duet3 DuetControlServer[1908]:    at DuetControlServer.SPI.DataTransfer.GetCodeSize(Code code) in /home/pi/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 527
      May  8 21:06:40 duet3 DuetControlServer[1908]:    at DuetControlServer.SPI.Channel.Processor.ProcessCode(Code code) in /home/pi/DuetSoftwareFramework/src/DuetControlServer/SPI/Channel/Processor.cs:line 280
      May  8 21:06:40 duet3 DuetControlServer[1908]:    at DuetControlServer.SPI.Interface.ProcessCode(Code code) in /home/pi/DuetSoftwareFramework/src/DuetControlServer/SPI/Interface.cs:line 211
      May  8 21:06:40 duet3 DuetControlServer[1908]:    at DuetControlServer.Commands.Code.Process() in /home/pi/DuetSoftwareFramework/src/DuetControlServer/Commands/Code.cs:line 412
      May  8 21:06:40 duet3 DuetControlServer[1908]:    at DuetControlServer.Commands.Code.ExecuteInternally() in /home/pi/DuetSoftwareFramework/src/DuetControlServer/Commands/Code.cs:line 336
      May  8 21:06:40 duet3 DuetControlServer[1908]: [info] File: Optional macro file start.g not found
      May  8 21:06:40 duet3 DuetControlServer[1908]: [info] Starting macro file homeall.g on channel File
      May  8 21:06:51 duet3 DuetControlServer[1908]: [info] File: Optional macro files deployprobe0.g and deployprobe.g not found
      May  8 21:06:56 duet3 DuetControlServer[1908]: [info] File: Finished intermediate macro file deployprobe0.g
      May  8 21:06:56 duet3 DuetControlServer[1908]: [info] File: Optional macro files retractprobe0.g and retractprobe.g not found
      May  8 21:06:56 duet3 DuetControlServer[1908]: [info] Finished macro file homeall.g
      May  8 21:06:56 duet3 DuetControlServer[1908]: [error] (comment) has thrown an exception: [ArgumentException] Failed to serialize code
      May  8 21:06:57 duet3 DuetControlServer[1908]: [info] Aborted job file
      May  8 21:06:57 duet3 DuetControlServer[1908]: [info] Cancelled printing file 0:/gcodes/xytest3.gcode, print time was 0h 0m
      The test file is given below:
      G28
      G1 X0 Y0
      Note that some slicers (like Prusa Slicer) generate long comment lines containing a version of the start and end gcode and other parameters. So this problem will cause gcode generated by those slicers to fail (luckily this is usually at the end of the file).
      The same files seem to be handled fine when not using SBC. Perhaps long comments could be truncated before being sent to the firmware?
      NOTE: I am using the LPC1768 version of RRF with SBC and DSF not a Duet3 board. However I think that this is a general issue and is not specific to the LPC build. On that topic a small plea to not solve this by simply making the buffers larger (at least on the firmware side), we are already struggling for space!
        Thanks, I've asked @chrishamm to look into this.
          gloomyandy
          Thanks, let me know if you need any more information. @jay_s_uk has reproduced this with a Duet3 so it looks like it is not LPC1768 specific.
          • chrishammundefined
            chrishamm administrators
            Thanks for the report, I'll truncate whole-line comments from DSF to RRF if they exceed 100 characters.
            Duet software engineer
              gloomyandy @chrishamm
              @chrishamm Thanks makes sense to me. May I also ask what the thought is behind sensing comments to the firmware? I assume there must be some situations in which the firmware interprets them in some way?
                chrishamm administrators @gloomyandy
                @gloomyandy I've added support for it because whole-line comments are used for object identification.
                  gloomyandy
                  Ah that makes sense! Thanks for the info Chris.
