SOLVED Javascript Error
I've recently started having a problem when I open up my config.g file I get disconnected and this error shows up.
× JavaScript ErrorA JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
Version: 1.22.2
Message: ResizeObserver loop limit exceeded
URL: http://172.16.1.144/
Line: 0:0
Error object: nullEverything else works - i.e I can print, send commands open other system files no problem, but the moment I open the config.g file I get disconnected....any ideas?
Try upgrading DWC to 1.22.6.
Worked a charm, thanks!
