Bed Heating Issue
  • New installation of a Duet2 WiFi running firmware 3.0 on a Leapfrog Creatr HS which runs on 24v and has a 24v bed heater.
    Cannot get bed to heat by activating heat bed in Tools menu.
    Getting warning stating to long to heat.
    By using M303 bed will heat to 60c then I can activate bed heating in Tools menu and will then regulate heating as normal.
    Have run M303 several times with M501 at end of /sys/config.g
    Also tried PID and Bang Bang
    Thanks
    08/05/2020, 17:50:53 M500
    08/05/2020, 17:50:23 Upload of config.g successful after 0s
    08/05/2020, 17:38:18 Auto tune phase 3, peak temperature was 60.5
    08/05/2020, 17:38:08 Auto tune phase 2, heater off
    08/05/2020, 17:29:20 Auto tune phase 1, heater on
    08/05/2020, 17:29:14 M303 H0 S60
    Auto tuning heater 0 using target temperature 60.0°C and PWM 1.00 - do not leave printer unattended
    Thanks
    M569 P0 S0 ; X servo physical drive 0 goes backwards
    M569 P2 S1 ; Y servo physical drive 2 goes forwards
    M569 P1 S0 ; Z servo physical drive 1 goes backwards
    M569 P4 S0 ; physical drive 4 goes backwards
    M584 X0 Y2 Z1 E3:4 ; set drive mapping
    M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
    M92 X66.67 Y66.67 Z960.00 E97.01:97.01 ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X24000.00 Y24000.00 Z250.00 E1500.00:1500.00 ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z100.00 E1000.00:1000.00 ; set accelerations (mm/s^2)
    M906 X1000 Y1000 Z1500 E1500:1500 I20 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X240 Y280 Z180 S0 ; set axis maxima
    M574 X2 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop
    M574 Y2 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop
    M574 Z1 S0 P"zstop" ; configure active-low endstop for low end on Z via pin zstop
    M558 P1 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
    G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
    M557 X15:215 Y15:195 S20 ; define mesh grid
    M307 H1 B1 S1.00 ; disable bang-bang mode for heater and set PWM limit
    M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
    M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
    M143 H2 S280 ; set temperature limit for heater 2 to 280C
    M307 H2 B1 S1.00 ; disable bang-bang mode for heater and set PWM limit
    M950 F0 C"fan0" Q500 ; Extruder Fan create fan 0 on pin fan0 and set its frequency
    M106 F0 H-1 S1 ; set fan 0 value. Thermostatic control is turned off
    M950 F1 C"fan1" Q500 ; Board Cooling Fan
    M106 P1 T45:65 H100:101:102 ; Starts to turn on when the MCU temperature reaches 45C and reaches full speed when the MCU temperature reaches 65C
    M950 F2 C"fan2" Q500 ; Hot End Cooling Fan create fan 1 on pin fan1 and set its frequency
    M106 P2 T45 S0.7 H1:2 ; set fan 1 value. Thermostatic control is turned on
    M563 P0 S"Extruder 0" D0 H1 F0 ; define tool 0
    M563 P1 S"Extruder 1" D1 H2 F0 ; define tool 1
    G10 P1 X15.01 Y0 Z0 ; set tool 1 axis offsets
    G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
  • @PatCub Hi there - I also have a Leapfrog Creatr HS which I am thinking of converting to Duet3D electronics. Did you manage to overcome the heated bed issue you posted about? Also I was wondering if you used an auto bed levelling system such as BL Touch? Any help/advice you wish to share will be gratefully received. Peter
