    Pt100 alternative
    • gabi68undefined
      gabi68
      Hi to all,
      I need a PT100 sensor because the old one failed (one wire detached from the barrel) . I found one on 3djake, quite expensive, but I bought it. My questions to more knowledgeable people:
      • can some other sensors be used (same family PT100)?
      • where I can find that type of "replacement" sensors?
      • there is a way to reinforce the sensors from e3d or other vendors?
      Thank you
      • Carloundefined
        Carlo
        Can you use a PT1000 ?
        uses the standard thermistor socket but much higher temp rating 450cish I believe.
