Homing after cancel print RRF 3.0
  • Hi
    I recently upgraded from RRF 2 to 3 and after the necessary changes every works except when I pause and cancel a print and try to start a new one...I cannot home and the print will not start. I have to power up and down in order to be able to home and then start a new print.
    Is there anything that changed in regard to pause and cancel a print?
    start.g
    G21        ;metric values
    G90        ;absolute positioning
    M107       ;start with the fan off
    G29 S2
    M703 ; config filament
    G28
    M376 H10 ;taper off bed level compensation
    M204 P1200 T2000			;Set accelerations (mm/s^2)
    G1 X15 Y5 Z5
    G1 Z0.2 F3000 ;move the platform down
    G1 F3000
    G1 X115 Y5 E10
    G1 Z21.75 F3000 ;move the platform down
    G29 S1
    pause.g
    ; pause.g
    ; called when a print from SD card is paused
    ; generated by RepRapFirmware Configuration Tool on Sat Feb 24 2018 12:46:55 GMT+0100 (Central Europe Standard Time)
    M83            ; relative extruder moves
    G1 E-10 F3600  ; retract 10mm of filament
    G91            ; relative positioning
    G1 Z5 F360     ; lift Z by 5mm
    G90            ; absolute positioning
    G1 X0 Y0 F6000 ; go to X=0 Y=0
    cancel.g
    does nothing
    stop.g
    M104 S0                     ;extruder heater off
    M140 S0                     ;heated bed heater off (if you have it)
    G91                                    ;relative positioning
    G1 E-1 F300                            ;retract the filament a bit before lifting the nozzle, to release some of the pressure
    G1 Z+0.5 E-5 X-20 Y-20 F3000 ;move Z up a bit and retract filament even more
    G1 X0 Y0                              ;move X/Y to min endstops, so the head is out of the way
    Cheers Alex
    Please try upgrading to firmware 3.01-RC12. There have been many improvements since 3.0.
  • was a bit hesitant to upgrade to an RC...but you would say that RC12 is more reliable than 3.0?
    @AlexLin said in Homing after cancel print RRF 3.0:
    Yes. We are very close to releasing RRF 3.01 stable.
    Read the upgrade notes because there are changes to configuration of PanelDue, bed heaters, and (in some cases) endstops.
