Steps/mm not being automatically adjusted when changing microstepping
  • I'm running into an odd issue when changing to anything other the 16x microstepping. It seems like the automatic adjustment of the M92 parameters is not working.
    I've done the following:
    1. Ensured that my M92 command follows the M350 command
    2. Ensured that I'm not just losing steps (the distance traveled is a multiple of the microstepping (1/2 as far for 32x, 1/4 as far for 64x, etc…)
    Here is an excerpt
    [[language]]
    ; Configuration file for Duet WiFi (firmware version 1.17)
    ; generated by RepRapFirmware Configuration Tool on Sat May 27 2017 15:46:30 GMT-0400 (EDT)
    M111 S0 ; Debugging off
    G21 ; Work in millimetres
    M208 X250 Y250 Z250 S0 ; Set axis maxima
    M574 Z0 S0 ; Define active low and unused microswitches
    M574 X1 Y2 S1 ; Define active high microswitches
    M558 P0 X0 Y0 Z1 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
    G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
    M557 X15:235 Y15:235 S20 ; Define mesh grid
    M569 P0 S1 ; Drive 0 (x) goes forwards
    M569 P1 S0 ; Drive 1 (Y) goes backwards
    M569 P2 S0 ; Drive 2 (Z) goes backwards
    M569 P3 S1 ; Drive 3 (E) goes forwards
    M350 X64 Y64 Z16 E16 I1 ; Configure microstepping with interpolation
    M92 X80 Y80 Z2020 E96 ; Set steps per mm
    M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
    M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
    M906 X800 Y1200 Z600 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M143 S270 ; Set maximum heater temperature to 270C
    M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
    M563 P0 D0 H1 ; Define tool 0
    M550 PPrintrbot Metal Plus ; Set machine name
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    The way that the automatic adjustment works is that when you run M350, the current steps/mm is adjusted to take account of the change in microstepping. When you run M92 the values you provide are assumed to be correct for the current microstepping. Therefore, if you use M350 first and then M92, then if you change the microstepping in M350 you need to also change the M92 values. Or you can use M92 first, using values appropriate for the default x16 microstepping, then when you subsequently use M350 the steps/mm will be adjusted automatically.
  • dc42, this is the section of the documentation that threw me for a loop:
    The M92 commands to set steps/mm must come after any M350 command to set microstepping. This is because when you change microstepping, the steps/mm are automatically adjusted to take account of the change in microstepping.
    https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer
    Thanks for pointing that out. I have updated the text, and I hope it is clearer now.
