Code SEND button misbehavior
  • Seems it takes two clicks of the dashboard SEND button to fire off a command. Hitting keyboard return requires a single click. Is this intentional ?
  • Moderator
    What version of the DWC are you using?
  • DWC 2.71 but also acted the same on an earlier version - 2.07 I think. Perhaps irrelevant but it is running in the Chrome browser
  • It can be reproduced even with newest 2.1.8. Load the page, force reload (ctrl+f5), type any command in the input field and press the button. Nothing happens. Press again and it sends, and seems to work untill a new force reload.
    In the source there is a comment "// FIXME There must be a better solution than this", so I guess chrishamm is aware.
