SOLVED RC12 [ArgumentException] Failed to serialize code
I just upgraded to RC12 on my Duet 3. I cannot start any print jobs anymore. I get the following error: "Error: (comment) has thrown an exception: [ArgumentException] Failed to serialize code
Can someone point me in the right direction?
Your gcode has some very long comments in it. See: https://forum.duet3d.com/topic/16221/dsf-2-2-0-long-comments-in-gcode-causes-an-exception/7
You may be able to work around it by editing the gcode files and deleting the long comment lines.
That is a work around but a pain to have to do that each time. On RC11 I had no issues
An updated DSF that fixes this will be availabe soon.
@dc42 Thank you!
@jdumoulin said in RC12 [ArgumentException] Failed to serialize code:
@dc42 Thank you!
If you can confirm that this is solved in release 3.1.1 stable, please mark this topic as solved.
@dc42 It solved it for me
