    New firmware 1.19 beta 2
    Firmware installation
    18
    70
    9.8k
    • gate546undefined
      gate546
      @dc42:
      I've just released this at https://github.com/dc42/RepRapFirmware/tree/dev/Release (look in the Edge folder for your board). See https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md for the full change information and important upgrade notes.
      what means this :"DuetWiFiServer-1.19beta1.bin Restored DuetWiFiServer-1.19beta1.bin"
      Thank you
      Dommy
        I accidentally removed that file from the Duet-WiF/Edge folder when I committed release 1.19beta6 of RepRapFirmware. So I put it back again.
        • Kulitorumundefined
          Kulitorum
          1.19 beta 6 does not connect
          I tried 1.19 beta6 but is unable to get the printer to connect to my wifi.
          After updating, and running the SetNetwork macro, I connect through USB and M552 returns "Wifi module is idle"
          Sending "M552 S1" and I get "Wifi module is changing state" for 1-2 minutes, then "Wifi module is idle" again.
          Ideas?
            Kulitorum
            Meh, M552 S2 responds:
            11:24:24.849 : WiFi reported error: invalid access point configuration
              Kulitorum
              M588 * does not work. Nothing is deleted
                Kulitorum
                So I try to get the machine into AP mode:
                11:45:44.303 : serial: N45 M589 S"DuetWifi" P"Silverspoon" I192.168.1.1*28
                And then M552 S2
                I get:
                11:46:03.063 : WiFi reported error: invalid access point configuration
                • tomasfundefined
                  tomasf
                  I don't think AP mode is implemented yet, is it?
                  But yeah, I have the same problem joining my network. It just sits there doing nothing, like it can't find the network at all. Signal strength should be fine, and no other devices have any problems joining at all.
                    Kulitorum
                    I got it to work by deleting all known networks one at a time and re-add my main wifi.
                    • vhowardundefined
                      vhoward
                      Beta 6 is actually working with my printer. Just need to figure out how to use the M587 command to delete previous wifi connections so I can re-enter the correct one.
                        @vhoward:
                        It's M588 that does that, see https://duet3d.com/wiki/G-code#M588:_Forget_WiFi_host_network.
                          @Kulitorum:
                          And then M552 S2
                          I get:
                          Did you use M589 to configure the access point parameter first? See https://duet3d.com/wiki/G-code#M589:_Configure_access_point_parameters. However, I haven't yet tested access point functionality, so it is more than likely that it doesn't work.
                          • vhowardundefined
                            vhoward
                            @dc42:
                            @vhoward:
                            Thanks. I will clean it up now. It has been behaving itself so far and just about to complete a 10 hour print.
                            • tomasfundefined
                              tomasf
                              Any plans for a G-code that scans for and replies with available WiFi networks?
                                @tomasf:
                                That requires some thought, because any existing connection to a WiFi network or existing access point that is being provided will have to be terminated in order to do the scan.
                                • vhowardundefined
                                  vhoward
                                  Well, It worked for one day. It will still print when I hook up via usb, but the wifi module will not work today. It just reports that the wifi module is idle. I am just going to replace the duet wifi with something else until you make the ethernet module available.
