Serial connection and opposite spin direction
  • Hi at all,
    Sorry for my "poor English"...:-)
    I'm looking for some information about the correct serial connection of two stepper motors for axis Y that has to spin in opposite direction controlled by Y driver of duet board.
    I found a lot of wiring diagrams in internet, but no one clearly explain to me how obtain the opposite direction.
    should I only connect two opposite motors windings (i.e A1 and A2 with B1 and B2)? or should i also to reverse the polarity of windings (i mean A1 with B1 and A2 with B2)?
    The first connection that i have done, is not working well....the motors only do a little confused movement without direction.
    Thanks for you help.
    Logriso
  • This is how I have done it in the past with a Duet board.
  • @Coffee Thank a lot...
    I will try....
  • Hi.
    I've tried and everything worked fine.
    Thanks again!
  • Good deal! You are most welcome!
