G29 not writing a heightmap.csv
Try as I might, I cannot get bed mesh leveling to write a heightmap anymore. I previously had it working fine, but upgraded firmware recently, and I'd say since then can't get it to work.
So initially I had a valid heightmap that I wanted to update, so ran G28>G29, but the heightmap remained unhanged.
After much faffing around, I reflashed duetpi-lite>sudo apt-get update/upgrade, recopied config and tried again
There is no heightmap.csv on the SD card
G29 seems to complete sucessfully, if you click on "compensation and calibration" button on dashboard it says "Compensation in use: mesh", however, there is still no heightmap.csv on the card, and heightmap tab says "File 0:/sys/heightmap.csv not found"
feels like maybe a user permissions issue?
Board: duet 3 6hc w/ SBC duetpi
Diag:
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.1.0 running on Duet 3 MB6HC v0.6 or 1.0 Board ID: 08DJM-956L2-G43S8-6J1F8-3SN6P-9V0QG Used output buffers: 1 of 40 (13 max) === RTOS === Static ram: 154804 Dynamic ram: 162712 of which 44 recycled Exception stack ram used: 544 Never used ram: 75112 Tasks: NETWORK(ready,2172) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1420) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,4536) IDLE(ready,76) Owned mutexes: === Platform === Last reset 00:21:49 ago, cause: software Last software reset at 2020-05-16 05:59, reason: User, spinning module LinuxInterface, available RAM 76888 bytes (slot 2) Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN Error status: 0 MCU temperature: min 32.7, current 33.9, max 34.2 Supply voltage: min 24.0, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.0, max 12.0, under voltage events: 0 Driver 0: standstill, reads 6042, writes 0 timeouts 0, SG min/max not available Driver 1: standstill, reads 6042, writes 0 timeouts 0, SG min/max not available Driver 2: standstill, reads 6041, writes 0 timeouts 0, SG min/max not available Driver 3: standstill, reads 6042, writes 0 timeouts 0, SG min/max not available Driver 4: standstill, reads 6042, writes 0 timeouts 0, SG min/max not available Driver 5: standstill, reads 6042, writes 0 timeouts 0, SG min/max not available Date/time: 2020-05-16 06:21:10 Slowest loop: 3.72ms; fastest: 0.15ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms Bed compensation in use: mesh, comp offset 0.128 === MainDDARing === Scheduled moves: 42, completed moves: 42, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is ready with "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon* is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 1.89ms; fastest: 0.01ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 0 of 8 - Ethernet - State: disabled Error counts: 0 0 0 0 0 Socket states: 0 0 0 0 0 0 0 0 === CAN === Messages sent 1065, longest wait 0ms for type 0 === Linux interface === State: 0, failed transfers: 0 Last transfer: 18ms ago RX/TX seq numbers: 42388/42390 SPI underruns 0, overruns 0 Number of disconnects: 0 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.1.0 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 32.59
Config:
; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Feb 02 2020 15:23:33 GMT+0800 (Australian Western Standard Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Duet 3" ; set printer name ; Drives M569 P0.0 S0 ; physical drive 0.0 goes forwards M569 P0.1 S0 ; physical drive 0.1 goes forwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M569 P0.3 S1 ; physical drive 0.3 goes forwards M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping M350 X32 Y32 Z32 E32 I1 ; configure microstepping with interpolation M92 X480.00 Y480.00 Z3200.00 E1666.66 ; set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E1500 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X230 Y210 Z200 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io0.in" ; configure active-high endstop for low end on X via pin io0.in M574 Y1 S1 P"io3.in" ; configure active-high endstop for low end on Y via pin io3.in M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"io7.out" ; create servo pin 0 for BLTouch M558 P9 C"io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X0 Y0 Z2.00 ; set Z probe trigger value, offset and trigger height M557 X15:195 Y15:195 S180 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C ;M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M572 D0 S0.075 ; pressure advance ; Custom settings are not defined M501
It seems like G29 completes internally in DCS before the actual probing has finished. I can save the heightmap properly by sending
G29 S3
once the heightmap is fully defined. You may use that as an interim work-around, too.
@chrishamm said in G29 not writing a heightmap.csv:
G29 S3
this worked. Can confirm that running a mesh level from the dashboard then manually sending g29 s3 saves the heightmap.
(manually sending a g29 s0 in the console causes the console to be stuck on processing and doesn't finish, so you cant sent any more commands)
