Duet Maestoro cannot connect to the Duet web control.
Hello.
I purchased M3D PROMEGA, but I am having trouble connecting to Duet web control.I looked at the following page and tried to solve it, but it was impossible.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38
https://forum.duet3d.com/topic/13860/duet-maestro-cant-connect-to-duet-web-control?_=1589777222908
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38#s137It seems that the M 997 S0 was able to update the firmware, but I could not connect even if I typed the IP address.
Is it because the IP address of PC and the IP address of Duet are different?
Does anyone know the cause? I would appreciate your help.!
@yurin said in Duet Maestoro cannot connect to the Duet web control.:
could be, depends on the rest of your network if it allows routing between the two networks.
Seems obvious that 2 devices in unequal network segments cannot reach eachother.
Are you convinced they are connected to the same router / network? It is not normal that devices in the same network get IP addresses through dhcp that are not in the same segments.
Thank you for your reply.
PC → wifi Duet → Router
I am connected to the Internet, so I will adjust it.
Hello.
As you said, when I looked up the IP address,
PC → IP address of wireless Wi-Fi
Duet → IP address of wired router
Could not connect because it was.I turned off the wireless wifi on my computer and connected it to a wired router, which connected me to Duet web control.
Thank you all for your help.
