g29 crash bed
hi, lately i'm having problems with self-leveling, i run the g32 perfectly with smart effector, after step to the g29 for the mesh, towards the last touches it slams the nozzle over the bed and stops, I checked all the cables with the tester are ok.
another problem that I'm having, during the press it doesn't respond to babysteps, it doesn't get up and it doesn't go down.
I attach my configuration
Duet Web Control 2.1.3
Board: Duet WiFi 1.02 or later (duetwifi102)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.05.1 (2020-02-09b1)
Duet WiFi Server Version: 1.23config.g :
; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Apr 20 2020 15:09:48 GMT+0200 (Ora legale dell’Europa centrale); General preferences
M550 P"kossel" ; set printer name
M665 R185 L360.27 B150 H371 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X160.00 Y160.00 Z160.00 E830.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E700 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 Y2 Z2 S1 ; set active high endstops; Z-Probe
M558 P5 R0.4 H5 F500 T5000 ; set Z probe type to effector and the dive height + speeds
G31 P100 X0 Y0 Z-0.175 ; set Z probe trigger value, offset and trigger height
M557 R120 S20 ; define mesh grid; Heaters
M305 P0 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P0 S0 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M501 ; load saved parameters from non-volatile memoryconfig.override
; config-override.g file generated in response to M500 at 2020-05-19 05:01
; Delta parameters
M665 L360.270:360.270:360.270 R185.199 H368.562 B150.0 X0.282 Y0.051 Z0.000
M666 X1.313 Y-0.872 Z-0.441 A0.00 B0.00
; Heater model parameters
M307 H0 A157.6 C626.6 D2.2 S1.00 V24.7 B0
M307 H1 A648.3 C115.7 D5.6 S1.00 V24.6 B0
M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
G10 L2 P1 X0.00 Y0.00 Z0.00
G10 L2 P2 X0.00 Y0.00 Z0.00
G10 L2 P3 X0.00 Y0.00 Z0.00
G10 L2 P4 X0.00 Y0.00 Z0.00
G10 L2 P5 X0.00 Y0.00 Z0.00
G10 L2 P6 X0.00 Y0.00 Z0.00
G10 L2 P7 X0.00 Y0.00 Z0.00
G10 L2 P8 X0.00 Y0.00 Z0.00
G10 L2 P9 X0.00 Y0.00 Z0.00
I think you need to go through this document to setup your smart effector properly.
It used to work perfectly, strangely now it's stopped. Now I read again this link that you posted to me.
