    What is the max safe mcu temp. for the duet maestro?
    My Duet controlled machine
    • maroondsundefined
      maroonds
      title says it all.
        I'm not sure. 80c probably. But the drivers will need much more cooling before then.
        https://duet3d.dozuki.com/Wiki/Mounting_and_cooling_the_Duet_2_Maestro
        https://duet3d.dozuki.com/Wiki/Mounting_and_cooling_the_board#Section_Cooling
        Be sure to calibrate the cpu temp so you know the reported value is correct.
          Probably 85C, but might be 105C depending on the exact MCU used.
