G codes not uploading to duet wifi
  • I'm having trouble uploading g code files to the duet wifi.
    I tried a new SD card and did the M122 code and saw that my connection is low but it should work.
    Sometimes when I try to upload a file it loads 100% and then gives an error or it gives an error 2 seconds after I try to upload it.
    Do you guys have any idea how I can fix this??
  • Moderator
    Can you post the results of your M122 please?
  • Here is the M122 of my printer. It worked fine until i moved it into another room. Could that be the problem? I also fully installed the cover on my duet wifi board.
    Thank you for your time and trying to help me 🙂
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later
    Board ID: 08DGM-917DA-G4MS4-6J9DA-3S86L-T8YHA
    Used output buffers: 6 of 20 (8 max)
    Static ram: 25524
    Dynamic ram: 98524 of which 0 recycled
    Exception stack ram used: 280
    Never used ram: 6744
    Tasks: NETWORK(ready,648) HEAT(blocked,1232) MAIN(running,3844) IDLE(ready,200)
    Owned mutexes: WiFi(NETWORK)
    Last reset 00:00:34 ago, cause: power up
    Last software reset at 2020-05-20 21:07, reason: User, spinning module GCodes, available RAM 6744 bytes (slot 3)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
    Error status: 0
    Free file entries: 10
    MCU temperature: min 28.7, current 32.7, max 32.8
    Supply voltage: min 24.2, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
    Date/time: 2020-05-21 10:04:12
    Cache data hit count 118212105
    Slowest loop: 5.08ms; fastest: 0.07ms
    I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
    Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
    Scheduled moves: 0, completed moves: 0
    Bed compensation in use: none
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 22.75ms; fastest: 0.00ms
    HTTP sessions: 1 of 8
    • WiFi -
      Network state is running
      WiFi firmware version 1.22
      WiFi MAC address cc 🙂
      WiFi Vcc 3.38, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 25448
      WiFi IP address 🙂
      WiFi signal strength -72dBm, reconnections 0, sleep mode modem
      Socket states: 4 0 0 0 0 0 0 0
  • @Fvanp -72dBm signal strength maybe a bit on the low side for a stable connection.
    Ideally, you'd be after something more in the 40s or 50s
  • I will try to move the printer back to the other room and try if the uploading works then. Sadly enough the printer is a bit to big to stay in the room with my router
  • @Fvanp you could look at either a WiFi repeater or power line adapters with built in WiFi. That should sort you out without having to move your printer.
    Or if you're feeling very adventurous, change the onboard ESP to an ESP-7S and then use an external antenna.
  • @jay_s_uk It is indeed my wifi, I tried it near the router and it worked fine. So I think I have to buy a wifi repeater. Thank you for your help sir.
    @Fvanp said in G codes not uploading to duet wifi:
    You may find that changing the WiFi channel used by the router helps.
