SOLVED Destroyed inductor L1
Hi! I incidentally hit inductor L1 with my screwdriver and completely destroy it.
I have desoldered it and check that pads for it are ok.I have found out from Tony's scheme placed on GitHub that its inductance is 22uH... but what resistance or maximum current I have to select for order from a chipstore?
Also should I choose a shielded version or unshielded will be ok too?
The inductance is not critical, neither is the resistance - anything below 1 ohm should be OK. The current flowing through it is less than 50mA. I think the part number we use is MLZ2012P220WT000.
David, many thanks for such a rapid response!
