SOLVED setting negative coordinate values with G92
I have a cartesian setup and I want my 0,0,0 home to be in the center for X and Y. For instance, my X settings range from -243 to 243 but when I home it is still setting the X min as 0 rather than -243.
I've tried adding "G92 x -243" to the end of homex.g and attempted entering it into the console. It does not seem to acknowledge negative values.
Don't use G92.
https://duet3d.dozuki.com/Wiki/Centering_the_bed_or_setting_the_bed_origin
Use M208 to redefine your minima and maxima values such that 0 is in the center.
Here's a detailed example: https://drmrehorst.blogspot.com/2018/07/ummd-better-way-to-set-up-origin-and.html
Thanks, It helped me find a typo in M208 as declared in config.g
Issue closed.
