delta g28 Error: G0/G1
  • Hello, I just installed my duer on my kossel + and I have the error g28 Error: G0 / G1: target position not reachable from current position,
    my configurationFirmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
    Duet WiFi Server Version: 1.23
    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri May 22 2020 23:06:00 GMT+0200 (heure d’été d’Europe centrale)
    G90                                            ; send absolute coordinates...
    M83                                            ; ...but relative extruder moves
    M550 P"Kossel Linear Plus"                     ; set printer name
    M665 R135.4 L271.5 B105 H300                   ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0                                  ; put your endstop adjustments here, or let auto calibration find them
    M552 S1                                        ; enable network
    M586 P0 S1                                     ; enable HTTP
    M586 P1 S0                                     ; disable FTP
    M586 P2 S0                                     ; disable Telnet
    M569 P0 S1                                     ; physical drive 0 goes forwards
    M569 P1 S1                                     ; physical drive 1 goes forwards
    M569 P2 S1                                     ; physical drive 2 goes forwards
    M569 P3 S1                                     ; physical drive 3 goes forwards
    M584 X0 Y1 Z2 E3                               ; set drive mapping
    M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
    M92 X80.00 Y80.00 Z80.00 E96.00                ; set steps per mm
    M566 X18000.00 Y18000.00 Z18000.00 E18000.00   ; set maximum instantaneous speed changes (mm/min)
    M203 X18000.00 Y18000.00 Z18000.00 E18000.00   ; set maximum speeds (mm/min)
    M201 X3000.00 Y3000.00 Z3000.00 E3000.00       ; set accelerations (mm/s^2)
    M906 X1000 Y1000 Z1000 E800 I30                ; set motor currents (mA) and motor idle factor in per cent
    M84 S30                                        ; Set idle timeout
    M208 Z0 S1                                     ; set minimum Z
    M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
    M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
    M574 Z1 S1 P"zstop"                            ; configure active-high endstop for low end on Z via pin zstop
    M558 P5 C"zprobe.in+zprobe.mod" H5 F120 T6000  ; set Z probe type to switch and the dive height + speeds
    G31 P500 X0 Y0 Z20.5                           ; set Z probe trigger value, offset and trigger height
    M557 R85 S20                                   ; define mesh grid
    M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
    M143 H0 S80                                    ; set temperature limit for heater 0 to 80C
    M307 H0 B1 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
    M140 H0                                        ; map heated bed to heater 0
    M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
    M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
    M143 H1 S250                                   ; set temperature limit for heater 1 to 250C
    M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
    M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
    M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
    M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
    M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
    M563 P0 D0 H1 F0                               ; define tool 0
    G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
    G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
    ; homedelta.g
    G91                        ; relative positioning
    G1 H1 X305 Y305 Z305 F1800 ; move all towers to the high end stopping at the endstops (first pass)
    G1 H2 X-5 Y-5 Z-5 F1800    ; go down a few mm
    G1 H1 X10 Y10 Z10 F360     ; move all towers up once more (second pass)
    G1 Z-5 F6000               ; move down a few mm so that the nozzle can be centred
    G90                        ; absolute positioning
    G1 X0 Y0 F6000             ; move X+Y to the centre
  • my Status
    Mode: FFF
    Position Outil
    X 1.0
    Y -0.1
    Z 566.01 😮
    Extrudeuse
    Moteur 0
    0.0
  • in reprap configurator , i haved select high but in config.g is low
    M574 X2 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
    M574 Y2 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
    M574 Z2 S1 P"zstop"                            ; configure active-high endstop for low end on Z via pin zstop
    first probleme resolved
