Your browser does not seem to support JavaScript. As a result, your viewing experience will be diminished, and you may not be able to execute some actions.
Please download a browser that supports JavaScript, or enable it if it's disabled (i.e. NoScript).
Hello i am building a new Printer and i want to use RRF2 but currently i am on RRF3, is there a easy way to downgrade the firmware?
Yes, you can use the same update process as normal to go to whatever version you like. Keep in mind the difference in config between the two.
