Cancel doesn't turn heaters off
  • Hi,
    I'm running firmware 3.1.0.
    When I cancel a print after pressing pause using the paneldue the heaters remain on.
    The contents of my cancel.g is;
    ; stop.g
    ; called when a print is cancelled after a pause.
    The contents of stop.g is;
    ; stop.g
    ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
    ; generated by RepRapFirmware Configuration Tool v2 on Tue Apr 30 2019 19:52:57 GMT+0100 (British Summer Time)
    This has happened a couple of times after upgrading the firmware.
    What's missing?
    Delete cancel.g or change it to turn off the heaters there (see G10 and M140).
  • Many thanks Chris
