What's the status of Duet2s supporting the RRF3 object model?
@dc42 When I try the official 3.1.1 RRF build on a Duet2, a request for rr_model results in
Your Duet rejected the HTTP request: Unknown request
If I build from an unmodified v3.01-dev branch which has
./src/DuetNG/Pins_DuetNG.h:64:#define SUPPORT_OBJECT_MODEL 1
I DO get a model.Was it disabled in the last release?
No, it wasn't disabled. You can verify that it supports the object model by using M409, which is the GCode counterpart to rr_model.
@dc42 Very weird. I had to flash the board again with the official build and it worked. It's also weird that when I tried to flash it with the official build again, I got an error about not finding Duet2CombinedIAP.bin. It's weird because how could I have gotten the other 3.1.1 builds to flash without it. Hmmm.
Anyway, problem solved. Thanks.
@gtj0, I can only think that you were running firmware 3.0 or another older firmware version.
